rear end housing trouble for 2004 Ram 1500
I have a broken LDS clutch clip that has ground its way into the bearing housing. I priced out new housings, but that path seems awfully expensive. Anyone have options? Junk yards don't seem like a good choice, unless I can find on that I'm positive isn't bent. I thought I had one secured from a fellow member, but he just sent pics and I can see that his in similar condition as mine. I guess the ideal situation is finding an open rear that someone switched over to a larger heavy duty axle. Then I could buy and install an aftermarket LSD in it, and I guess put a new set of 3.92s in as well.
Thanks,
Paul
Thanks,
Paul
Wow, it usually takes a lot longer than 15k miles for a broken clip to take out the housing. No signs of the broken clip at last diff fluid change?
I'd try to find one at a junk yard from a truck with a frontal wreak myself...
So I'm looking for a cherry housing, no damage at all... probably best if it is an open diff, I'm going with a new auburn or something else other than the poorly designed dana spicer that Dodge put in there.
