tail pipe smoke
Old Jul 11, 2012 | 10:32 PM
tav's Avatar
tav
Default tail pipe smoke
2003 hemi with 124,000.00 . about a thousand miles ago or so been noticeing some smoke comming out of the tail pipe mostly on when you start off just wondering what and the problem might be.
Old Jul 11, 2012 | 11:13 PM
joebaum's Avatar
joebaum
Valve guide seals
Old Jul 12, 2012 | 07:01 AM
MikeHTally's Avatar
MikeHTally
Just start up or just start off? Start up is valve guide seals. Start off may be something different.
Old Jul 17, 2012 | 08:41 AM
tav's Avatar
tav
when i had (i think ) the original muffler on i saw more smoke but since i had to replace it theres less.....but yes i do see it when mostly when i start off at lights . is that a big job ?
Old Jul 17, 2012 | 05:49 PM
p38251's Avatar
p38251
Sounds like rings. Allowing oil to blow past and burn. Most would reccommend engine rebuild or crate motor.
Old Jul 22, 2012 | 11:13 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If it were rings it would smoke ALL the time.
Just pull the heads, take them to the machine shop and let them redo them
