rearend front seal
Old Jul 13, 2012 | 08:21 AM
dirtballer's Avatar
dirtballer
Default rearend front seal
Does anybody know how to get the front seal out of the rearend of a 04 dodge ram1500 2 wheel drive.
Old Jul 13, 2012 | 04:31 PM
TrueDogman's Avatar
TrueDogman
Im guessing ur talking about pinion seal (at driveshaft). Put a small scribe mark or punch mark on nut and pinion by the threads. This is so that u can put nut back on in the same location. Holding pinion flange, remove nut and washer. Remove flange with a soft faced hammer or similar. Using old screwdriver or similar, pry old seal out, taking care not to scratch or damage seal mating surface. Carefully drive new seal into housing. Replace flange onto pinion splines. Install washer and nut, and tighten...aligning the scribes u made before disassembly. check diff oil Hope this helps.
Old Jul 14, 2012 | 05:51 AM
abarmby's Avatar
abarmby
I've never done this but, have read to count the number of turns you back the pinion nut off. Remove the old seal and reassemble as stated above.
Put a "new" pinion nut onto the pinion and count exactly the same number of turns and line up your marks.
Then, add a quarter turn.
Al
