Jumper wire !?!?!?!?
Old Jul 13, 2012 | 08:07 PM
TheTietzify's Avatar
TheTietzify
New Member
Default Jumper wire !?!?!?!?
Just bought the xpresskit PKCH1 for my keyless entry and push start system from "advanced keys".
On step 4 of the xpresskit manual is says "Using a jumper wire, power up vehicle ignition, without starting vehicle, for approx. 10 secs."
Now my question is: How do I do it??? What is a "jumper wire" and how do I power up the ignition with it?
I googled the $hit out of my laptop but no luck so far.
Would really like to install it this weekend so any help is appreciated.
Here is the link to the manual.
Thanks
TheTietzify
Old Jul 14, 2012 | 11:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You know, if you arent electrically inclined, you might wanna step back from this one.
A jumper wire is a piece of wire you can make or buy (Radio Shack) that you use to temporarily touch from a power source to something you are trying to power.
Powering up the ignition means simply turning the key to ACC or Run but not Start. This should power on everything in the truck except the starter.
Glad to see you over here brother. Its been a while since Ive seen you around
Old Jul 15, 2012 | 12:12 AM
TheTietzify
New Member
Hey weed,
thanks for replying. Any suggestion for a bypass I could use or is there a way i can do it without the bypass?
Have been taking it easy, btw I will contact you probably next week for the new bezel I need.
Old Jul 15, 2012 | 12:17 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I dont have enough info to help really. The link to the manual I found is HERE but it didnt say anything like what you are talking about.
