passerger window
Old Jul 15, 2012 | 02:13 PM
froy's Avatar
froy
Default passerger window
This week the passerger door window switch stoped working. I can open window from drivers door pannel and can close it with passenger door switch. just can't open from passenger door switch. Is it a bad switch or do you think its a broken wire inside one of the doors?
Old Jul 15, 2012 | 11:26 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My vote is the switch but since checking the wires is free, you should start there first
Old Jul 16, 2012 | 12:15 AM
natedoggsr71's Avatar
natedoggsr71
I had the same problem, for some reason 2 weeks later it started working again. I would like to know what cause that though.
Old Jul 16, 2012 | 02:58 AM
meecrob28's Avatar
meecrob28
I had the same issue and it turned out to be the wiring in the rubber boot between the frame and the door. The insulation had become extremely brittle over time - I had exposed and broken wires all over the place. As Weed said, looking into the wiring is free and that's where I would begin
