Head light power issues
Old Jul 15, 2012 | 03:22 PM
XLR8ONU's Avatar
XLR8ONU
Default Head light power issues
Ok so here goes.
I am having right side head lamp issues on my 2007 2500 Hemi Mega Cab.(Stock lights) Basically from what I have tested I know the bulb is good and I am getting no power to the connecter through the low beam power wire or the high beam power wire. I verified no power using a test light at the wire about 6 inches back from connector to ensure it was not just a bad connector.
Looked at the wiring diagram and it says the wires run back to the totally integrated power module(which is the fuse box from what I can tell.) Although I do not know which fuse if any is for head lamp. The map on lid of fuse box does not show any for head lights.
The next thing I am going to do after posting this, is to pull the switch and see If I have power there and make sure no wires are pulled out from the connector.
Any other Ideas you guys have would be great, cause i'm running out of them!
Thanks
Aaron
Old Jul 15, 2012 | 07:38 PM
MoparPaul's Avatar
MoparPaul
Sounds like the TIPM might of took a crap.
Here's a link
https://dodgeforum.com/forum/3rd-gen...sues-tipm.html
Old Jul 15, 2012 | 11:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed on the TIPM
