Popping and Creeking in Front Suspension
I have a video of my 05 SLT 5.7 4x4 of the popping and creeking that happens when I turn the wheel (most noticeably turning left). I tried to upload it (it's a 3.5mb .mp4 file) but obviously couldn't. If anyone knows how or a way I can upload it to another site for people to go to that would be great.
Again it's a creeking mostly when I am in park but driving, usually backing up slowly or pulling in slowly, the front end will creek and occassionally pop. It's not incredibly loud but I can definitely hear it and I can barely feel it in the floor board on the driver's side.
The brakes, calipers, ball joints have either been done recently or are in good shape. Only thing I was thinking it could be was the driver's side rack and pinion. I did the ball joints recently and I was sure to grease the gear and it slid in without issue. Maybe it is supposed to go in with the teeth lined up a certain way that the repair manual neglected to mention?
Thanks for any opinions or advice.
Yea mines nothing like that. On mine I get a pop, like a spring box on a mattress does when you jump on it wrong, when you turn the wheel at full lock only. That creeking seems like it could be coming from your tie rod somewhere around the boot
The tie rods are original by the looks of them (I'm the 3rd owner). By accident I got into the truck today and used the side step which I usually don't. My wife wanted them for when she drives it. When I did step on it I heard the creek just slightly. I bounced on it and heard it a bit more. Think it could be the shock? Only thing is I don't here the creek driving straight going over typical road bumps.
I would just start replacing stuff but everyone knows how a ball joint here, a tie rod there, etc and the cost adds up quickly. Not to mention the time it takes. That and I'm concerned about putting new 20" on if my suspension is off. Now that could hurt the wallet.
I'll stop by a local shop and see what they have to say. Thanks again.
So I took it to a local shop. One of the benefits of a small town is that after talking to the owner about my problem he let me use his drill, bit, creeper, grease gun, and air hose to drill a small hole in the boot of the tie rod, I put the small narrowed grease adapter on and filled the sealed tie rod with grease.
That was the only thing he could think of that it would be. I'll post back once I drive it a bit to see if it quiets down. But if anyone has any other suggestions I'm still open to any other possiblities.
Ok so it's not the tie rod. I'm stumped. I did notice that there is a rubber boot that is pretty badly deteriorated on the torsion bar. I've never had any reason to add, remove, or adjust it but I'll grease it up and see what happens.
Not that I'm complaining about the lack of replies but I think the best thing about me posting this problem and the progress is that I am kind of verbalizing the problem to myself and it seems to help. Enough of the Freudian bull**it.
I'll post the results.
Trending Topics
I don't think this is it, but check your bolts on your step bars. Mine would make a pop sound when I turned. Found bolts were tad bit loose on steps. Didn't know til you put a wrench on it. Didn't feel loose stepping on it.
