Old Aug 6, 2015, 02:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
suggestions on replacement brake rotors and pads
Old Aug 7, 2012 | 10:53 AM
DWCEngland03's Avatar
DWCEngland03
Also 1 last question. Do you recommend replacing the brake fluid at 60k or should it be ok?
Old Aug 7, 2012 | 11:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I used to buy a lot from Autozone but when I learned you could simply google and use checkout codes online for Advance, I changed who I spent money with for the most part.
Rockauto is nice but not like you can send back parts to them once they are worn out like you can a local store.
If you want to change your brake fluid, and yes it is recommended, go to Advance or Auto or someplace of the like (even Harbor Freight) and get the One Man Brake Bleeder ($5-8) and save yourself A LOT of time and headache.
