Throttle body cleaning
Old Aug 14, 2012 | 02:38 PM
  #21
willdikem66's Avatar
willdikem66
Originally Posted by Dead2Fall
Buckle the seatbelt
Pull the PCM fuse
Turn the key to the on position
Wait for the 3 chimes then turn to off
Put the fuse back in and it is now reset.
Easier way, and keeps all your radio settings and whatnot! Also, I believe resetting the PCM re-zeroes the IAC and TPS anyhow.
This is my new way of reseting the pcm thanks Dead2Fall! Tired of putting radio stations again
Old Aug 14, 2012 | 02:42 PM
  #22
EEE23238's Avatar
EEE23238
I agree. Will definitely do this next time instead.
Old Aug 14, 2012 | 05:08 PM
  #23
08HEMI1500's Avatar
08HEMI1500
My radio stations don't reset when I undo my battery... Even when it was off for the 4+ hours of changing spark plugs. Sucks for you guys lol
Old Aug 14, 2012 | 05:32 PM
  #24
willdikem66
Pshhh!
Old Aug 14, 2012 | 05:46 PM
  #25
joebaum's Avatar
joebaum
Getting the evap monitor to run is 1 of the toughest , probably need 3/4 tank of fuel and possibly many miles before it will run. But I'm wishing u the best. We need more detailes of shut down.
Old Aug 15, 2012 | 02:53 AM
  #26
Billy Javis's Avatar
Billy Javis
My 4.7 started shuting off also turned out to be the tps sensor, 35 bucks at advance.
Old Aug 15, 2012 | 10:35 AM
  #27
willdikem66
Glad to know my guess was some what right lol. I just hope she dont have to buy a new one.
Old Aug 15, 2012 | 11:57 AM
  #28
EEE23238's Avatar
EEE23238
So here's an interesting twist!
Haven't had a chance to look at the throttle body yet but the check engine light came back on with the EVAP codes. But now the truck doesn't die at idle. Would it make sense to assume there is a hose/vacuum issue somewhere that the computer is compensating for? Guess I need to take it in to get a smoke test because I can't find any other holes. Any other thoughts?
Not sure if this is relevant, but the truck was dying at idle when the engine was still cold. Once the engine got going it was ok.
Old Aug 15, 2012 | 12:00 PM
  #29
willdikem66
Smoke test would be a good start but you may not have a leak. What are the codes this time?
Old Aug 15, 2012 | 03:57 PM
  #30
EEE23238's Avatar
EEE23238
PO440. But I replaced the gas cap three weeks ago so it shouldn't be that.
