2004 RCSB 4x4 Front End noise
Old Aug 20, 2012 | 01:59 PM
jwhirl06's Avatar
jwhirl06
Default 2004 RCSB 4x4 Front End noise
I've got an 04 RCSB Hemi ram, it started making a weird clanging noise from the front drivers side tire, it is not a clunking noise but more a clang, like the heat shield for the rotor is catching on something. I pulled the tire off, there's no play in the wheel bearing, cv axle and all of the joints are nice and solid. I'm at a loss. It usually happens when I make a sharp turn, then goes away when the wheels are straight. 4x4 does NOT trigger the noise. I thought I may have had a rock or something stuck in the rotor but I just changed them out not even 2 months ago.
Old Aug 20, 2012 | 02:01 PM
jwhirl06's Avatar
jwhirl06
also I should note, this happened randomly after I put the truck in reverse and backed out of a parking spot with the wheels turned, it felt almost like the brakes were engaged as I could feel some resistance.
Old Aug 20, 2012 | 03:49 PM
willdikem66's Avatar
willdikem66
Im having the same sound it sounds like!
Old Aug 21, 2012 | 10:49 AM
jwhirl06's Avatar
jwhirl06
bump. I noticed the ride is a bit wobbly at 60+. I believe this has factory wheel hubs on it still. I'm going to start with those, because they're cheaper than replacing a CV axle that doesn't 'appear' to be broken.
Old Aug 21, 2012 | 03:39 PM
willdikem66
Thats how mine is here just recently at some speeds ive noticed some wobble
Old Aug 24, 2012 | 01:37 PM
jwhirl06's Avatar
jwhirl06
Can anyone chime in if this is the part I need to replace the CV axle?
http://www.cardone.com/Products/Prod...=663316&p=rock
