Do i need to lift it?
Old Aug 21, 2012 | 10:28 PM
4.7L's Avatar
4.7L
Default Do i need to lift it?
Hey fellas, i got a stock '02 1500. I wanna put 34-35" tires with 20" rims on it, but i don't know if it will fit with stock height, maybe if i set the torsion bar all the way up and add a leaf spring or two? Any info would be appreciated! Its currently on stock tires/rim, 275/70R17. Thank guys
-Dave
Old Aug 21, 2012 | 10:59 PM
scwpd's Avatar
scwpd
Look at the sticky for wheel and tire fitment it will tell you what you need to know
Old Aug 21, 2012 | 11:09 PM
04HemiGreg's Avatar
04HemiGreg
Yes, read the sticky. You will probably need to level it to fit tires that tall. But to go much wider, you will need a rim with some negative offset and good backspacing.
Old Aug 21, 2012 | 11:22 PM
willdikem66's Avatar
willdikem66
It will fit 35s with tbars cranked but make sure you dont over do it
Old Aug 22, 2012 | 07:28 PM
4.7L's Avatar
4.7L
whats negative offset and backspacing? And what do you mean by over do the tbars?
thanks for the help guys
-Dave
Old Aug 23, 2012 | 01:22 PM
willdikem66
If you over tighten the t bars it will cause parts to fail prematurley. You would see the tires lean in or out as if the ball joints were out
Old Aug 24, 2012 | 12:06 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Anytime yoy lift or drop or play with the suspension parts, you need to go get an alignment
Old Aug 24, 2012 | 11:52 AM
Arctodus's Avatar
Arctodus
Have fun pushing 35" with a 4.7, make sure you budget for gears or you won't be able to get out of your own way.
Old Aug 24, 2012 | 11:41 PM
4.7L's Avatar
4.7L
so a 4" lift with an alignment, and what a 4.7 magnum won't be able to go with 35" tires? c'mon. but I'm prob gonna go with 33-34" tires
Old Aug 25, 2012 | 07:53 AM
dirtydog's Avatar
dirtydog
Moderate User
-Dave
Everything said/asked here is in the Sticky. Seems you may have not found it so here it is.
https://dodgeforum.com/forum/3rd-gen...dodge-ram.html
33" is stock height for 20's so they'll fit no matter what. Width is issue. Read sticky about all that.
Going 35's reduces your overall gear ratio and inturn reduces your low end torque output at low speeds. You will notice a power loss with 35's because the engine has to work harder to move the larger diameter tires. Works the same was as your front crank on a mountain bike does. Try to pull a wheelie while it's on the larger crank sprocket. Doesn't happen. Same thing except you'll never be able to wheelie your truck...lol
