10kmi front diff change
Old Aug 24, 2012 | 11:45 PM
dakotatrevor's Avatar
dakotatrevor
I don't really understand why there was so much moisture in your front diff. Do you go in and out of a heated garage for parking?
Originally Posted by Dead2Fall
Clean the cover with brake cleaner. Don't shoot brake cleaner inside the diff itself. Odds are you wont get it all out and it could affect your oil. Wipe it out with a clean rag.
The idea of brake clean is that it evaporates...I wouldn't spray directly into the bearings, as its good to leave oil in them.
Old Aug 25, 2012 | 07:35 AM
dirtydog's Avatar
dirtydog
Moderate User
Nope. It stays parked in my driveway, but the weather rapidly changes here in NY so the case dews all up with moisture on rapid temp changes. There is a vent that comes off the cover and routes up near the battery tray, but since I dont drive it much to circulate the fluid, the moisture remains inside with the oil.
While even brake cleaner eveaporates, it can still remain in the oil and contaminate it. I would reccomend spraying the fluid on a rag and using the rag to wipe out the inside. This way it doesn't get all over and your in control.
I just wiped the bottom out. I did not wipe down any of the components like cages on the bearings, ring gear, carrier because the sludge stuff was all at the bottom luckily. I got most of it out anyway. Some stays in the axle shafts but that's to be expected unles you pull out the axles....pffft, I aint that crazy.
