2005 Ram 1500 Laramie Quad Cab
Old Aug 25, 2012 | 09:38 AM
nlagred's Avatar
nlagred
Default 2005 Ram 1500 Laramie Quad Cab
I'm looking at purchasing a fifth wheel camper and plan to pull it with my 2005 Ram. The problem that I'm having is I can not find a definite answer on towing capacity of my truck. The truck is a Quad Cab, 4x4, 6ft bed, 20" wheels, and 5.7 Hemi. Not sure what other details are needed but let me know if more are.
The camper that I'm looking at has a total dry weigh of 6360 lbs and a tongue weight of 1120. The only thing that I'm thinking is that the rear suspension might need a little beefing up. I've towed a number of trailers, boats and other things with the truck but never a fifth wheel and nothing this big and heavy.
Any assistance is greatly appreciated.
Thanks
NL
Old Aug 25, 2012 | 10:12 AM
dirtydog's Avatar
dirtydog
Moderate User
Here's the towing capacity/limit breakdown by truck style
http://dodgeram.info/2004/load-tow/1500.html
Those weights max you out. I'd keep your packing load light.
I would recc'd airbags for the rear suspension. They are between $180-300 depending on brand. They aren't that difficult and can be done in your driveway for install.
Old Aug 26, 2012 | 06:49 AM
nlagred's Avatar
nlagred
Thanks for the info and the link dirtydog! The link says it's for 2004 Dodge Ram and I'm guessing that the weight ratings didn't change for 2005's? Any recomendations on brand of airbags or where to purchase from?
NL
Old Aug 28, 2012 | 06:01 PM
p38251's Avatar
p38251
I have firestone on mine. Huge differance when towing BTW my TT is 8500k Which is about the max with 3.92 gears. I have 4.56 However it does change the fact the braking system is only set up for that weight. Rec at least 3/4 ton.
Old Aug 28, 2012 | 06:13 PM
gcburkett's Avatar
gcburkett
You are probably going to exceed your GVWR on the truck. Some people don't mine that too much but you probably don't want to exceed the rear axle rating. You might want to weigh your truck with everything in it that you would normally take while towing and see where you stand on weight on the rear axle. A fifth wheel hitch adds another 100-200 lbs depending on whether it a slider or not.
