Whistling/hiss from motor
Old Sep 26, 2012 | 12:44 PM
  #41
willdikem66's Avatar
willdikem66
Oh i misunderstood you i thought you were talking about on the trans side sorry i was reading to fast
Old Sep 26, 2012 | 01:15 PM
  #42
Izero's Avatar
Izero
Just use the fluid recommended in the Owners Manual... Dodge vehicles do not like anything other than OEM equivalent fluids, I've noticed.
Specially when it has to do with their Mopar Friction Additives.....
Old Sep 26, 2012 | 01:59 PM
  #43
redram2007's Avatar
redram2007
cool i wasnt sure if i should use oem or expensive synthetic fluids.
Old Sep 26, 2012 | 02:02 PM
  #44
Izero's Avatar
Izero
OEM Trans/Diff fluid is best for anything Dodge I've found... can't go wrong with it.
This is my 3rd Dodge, I used an expensive synthetic on an auto trans on my 2nd Dodge and the thing freaked out, shifted all kinds of funny (even rough at some points), didn't sound right... drained it and put OEM stuff in... wow! What a difference!
Old Sep 26, 2012 | 02:15 PM
  #45
redram2007's Avatar
redram2007
Awesome thanks again for all the help and info guys
Old Feb 18, 2013 | 09:24 AM
  #46
jleonard's Avatar
jleonard
Update or fyi, the hissing turned into a whining in January. Changed the belt tensioner pulley. Noise is gone. Started to sound like a bad ps pump! Izero was correct in the very beginning.
Old Jun 13, 2014 | 10:43 AM
  #47
NJSquatch's Avatar
NJSquatch
Originally Posted by redram2007
I have the same problem. mine is a low whistle and only happens when light throttle is applied. It started after i cleanded throttle body and used seafoam treatment in the vacuum line. i installed all new gaskets and checked for vacuum leaks as well as cai connections no leaks found.
Redram2007 just wondering if you ever found the source of your whistle? I am experiencing something similar. Thanks
Old Jun 13, 2014 | 12:38 PM
  #48
Izero's Avatar
Izero
Glad I could help.
