Whistling/hiss from motor
Old Aug 26, 2012 | 07:22 PM
jleonard's Avatar
jleonard
Default Whistling/hiss from motor
2005 Hemi 1500. Got a new sound in the engine compartment. Sound like almost a whistle or whine when under acceleration. Almost sounds like a SC. No air intake leaks, thinking maybe egr or pcv valve if it has one. Any ideas?
Old Aug 27, 2012 | 08:47 AM
Izero's Avatar
Izero
Sounds like you might have a bad pulley or a loose belt somewhere....
Could also be your transmission.
1) Check the slack (or lack thereof) in the belts
2) Check Trans Fluid (might want to change it just to be safe)
3) Find exactly where the sound is coming from.
4) Check the Power Steering fluid & pump
Old Aug 27, 2012 | 08:51 AM
drewactual's Avatar
drewactual
clean the throttle body.. 'sounds' like you're gummed up..
Old Aug 28, 2012 | 05:49 PM
p38251's Avatar
p38251
I have the same noise. Alternator bearing is what mine is. Been doing it for 100k. I tell everyone it has a super charger LOL.
Old Aug 28, 2012 | 09:20 PM
jleonard's Avatar
jleonard
Inteteresting comments. Cleaned TB two days ago, new mopar alternator last year, belt has 40k on it. Does not sound like a whine that a tranny or ps pump would make. Had tranny flushed last fall so I think Im good on that end. Its only on acceleration or revving the engine. Maybe a pulley bearing, I'll have to look deeper into that.
Old Aug 28, 2012 | 09:24 PM
Dead2Fall's Avatar
Dead2Fall
Do you have a cai? If so you are most likely hearing the vacuum behind the butterfly in your tb pulling air past the blade.
Old Aug 28, 2012 | 09:25 PM
Dead2Fall's Avatar
Dead2Fall
Or a possible vacuum leak somewhere...
Old Aug 28, 2012 | 09:26 PM
drewactual's Avatar
drewactual
Information emerges..... You cleaned tb a couple months ago.. when you did, did you re use the gasket that goes between it and the intake manifold? If so, that was a no-no..
On my family of engines, which is small block mopar 318/340/360, that is the leading reason for whistle on acceleration..
Old Aug 28, 2012 | 09:29 PM
drewactual's Avatar
drewactual
I can't comprehend what I read, apparently.. if the whistle is persisting after cleaning tb TWO DAYS ago, that obviously isn't your issue, unless you missed the iac when you did it..
Another thing to look at is o2 sensors.. whatever the relation, they've been known to cause whistling too..
Old Aug 28, 2012 | 09:48 PM
Dead2Fall's Avatar
Dead2Fall
I reuse my gasket with no trouble at all. Get a smoker to blow a few puffs around in there and see what's sucking air If its more a whistle than a whine. What type of intake and filter?
