Headlight Adjustment Troubles
I was attempting to adjust my headlights due to the truck now being leveled, and the driver's side adjusted fine, but I was not able to adjust the passenger side. It seems like the head of the adjustment screw is stripped because my torx T20 bit just spins and it doesn't seem to engage the screw at all. What's strange is that I used my T15 bit to adjust the driver's side, but it's too small for the passenger side, and the T25 is too big. So I'm a little stumped. Is there any other way to turn the adjustment screw?
If the piece of plastic that surrounds the head of the adjustment screw had a bigger opening it looks like I could get a socket on it, but there's just not enough clearance as it is. I might spray it down with Blaster and see if that loosens anything up.
