ABS brakes
Old Aug 29, 2012 | 05:37 PM
Dean Deeter's Avatar
Dean Deeter
Default ABS brakes
Do all 2004 dodge rams have abs brakes?? Reason I am asking the abs light came on today with the brake light(emergency). I understand it could be the speed sensor. I got underneath the truck and see no electrical going to rear brakes at all. I just replace a front bearing and I know it does not have front abs. Was wondering if the lights would come on because of the speed sensor even if no abs aqre present.
Old Aug 29, 2012 | 06:01 PM
jasonw's Avatar
jasonw
Site Moderator
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Aug 29, 2012 | 06:39 PM
Toefur's Avatar
Toefur
Yes, your Ram has either rear wheel abs or all wheel abs.
Old Aug 29, 2012 | 10:45 PM
Brad Charais's Avatar
Brad Charais
the sensor for the rear abs is located on the diff housing. the front are in the hubs (4X4)
Old Sep 1, 2012 | 08:05 PM
Dean Deeter
While I was under the truck I noticed moisture on the inside of driverside front tire. I checked it out and the brake line had a leak, I replaced the brake line and now the abs and brake light has went out. Must have been a indicator that there was a brake problem and not just a bad abs sensor.
Old Sep 3, 2012 | 10:22 AM
Dean Deeter
Fixed
