Exhaust leak - Broken Bolt
09-05-2012, 05:10 PM
on
Quote:
Originally Posted by
willdikem66
I took mine off and it helped with a small noise near the motor. it really dosent add that much heat
Thats what im trying to do.
Im trying to diagnose and stop a noise im having and just trying to do one thing at a time. So it wont cause any problems taking the heat shields off?
What are they held on by? Just some nuts on the same studs that hold the manifolds on?
09-05-2012, 05:30 PM
on
yeah cant remember the size but theres like 5 on each one
09-05-2012, 06:52 PM
Hall of Fame Member
Heat shields are nice but still heat will rise and radiate. You can always be do what I did and get ceramic coated headers
09-05-2012, 06:54 PM
on
weedahoe
Where did u get those at ? Im looking for some for my 74 vette and my 08 hemi. I keep burning up the starters on my vette
09-05-2012, 07:57 PM
Hall of Fame Member
I have Pacesetter long tube on mine. You can find them on many sites as well as ebay
09-06-2012, 07:24 AM
on
got the broken bolt out last night. What a relief. I drilled the pilot hole, then was able to literally unscrew it by hand with the ez out.
Replaced all of the bolts w/ some heavy duty stuff and the noise is gone.
Thanks for your help guys.
09-21-2012, 02:40 PM
on
snidehockey
What type of heavy duty replacement bolts did you use, out of curiousity?
09-21-2012, 02:48 PM
on
Glad you got it fixed, Someone has worked on my truck previously and broke a secondary head bolt off. Im at a stand still now wonder if i could just drill a pilot hole and get it out.
09-21-2012, 03:55 PM
Hall of Fame Member
RamStar86
I used Grade 5 or 8 (I forget which now) with lock washers and have never had any issues.
09-23-2012, 11:17 AM
on
I went with grade 8.8 I think.
unfortunately the noise is in fact still there - came back after a day or so...replaced the gasket and everything...not quite sure what to try.
