Lost Cruise Control and Overdrive 2007 1500 HEMI
Subscribe
Sep 3, 2012 | 12:09 PM
Early last week I lost my cruise controls and my overdrive, on my 2007 1500 4wd QuadCab HEMI.
Have replaced brake peddle sensor, crank shaft sensor, and cam shaft sensor. Still have problem. Engine light is on, and I get a code for "Cam Phasing Alinement".
Each morning, when I start truck, the engine light comes on and chims in. But the cruise works for about 5 miles, and the truck goes into overdrive and will stay there for about 7 miles.
The OD switch is working as I can cycle through the normal, NO OD and Towing modes.
All fuses look fine.
I have NOT changed out the transmission speed sensor, so does anyone think that could be part of the problem?
I have 185k miles on the truck and have never had any problem with it until now. Been a great vehicle.
Thanks,
Rick
rihockrn@aol.com
Reply 0
Sep 10, 2012 | 05:44 PM
Bump. Help please.
Reply 0
Sep 20, 2012 | 12:08 AM
mine does the same thing
but only when it rains, when it's dry works fine, also Ive found if im rolling fast enough it should be in o/d if I shut ign off for a sec then tun it back on it goes into o/d and the cruise works has to be a sensor gettng wet
Reply 0
Sep 20, 2012 | 12:52 PM
Quote: but only when it rains, when it's dry works fine, also Ive found if im rolling fast enough it should be in o/d if I shut ign off for a sec then tun it back on it goes into o/d and the cruise works has to be a sensor gettng wet
That or you dont have a good ground, short in the wire, connector not connecting
Reply 0
Subscribe
