steering problem
Old Sep 6, 2012 | 02:05 PM
dodgeram22871's Avatar
dodgeram22871
Default steering problem
hi all, i have 2003 ram 2500 with a 5.9 diesel with a steering fault in it . with the jeep starting i can turn the steering to the right but not to the left and when the jeep is moving its ok.the fluid is ok ,tire pressures are at 60psi, the belt is not loose or worn . has anyone out there has had the same problem . thanks for reading my post.
kevin spillane
