Transfer case
Old Sep 12, 2012 | 05:54 PM
djsim1056's Avatar
djsim1056
Default Transfer case
Have an '07 Big Horn 1500, how do I tell which transfer case it has the, manual states for lubrication -Transfer Case ATF+4 fluid, but says if it's a NVG 246 to run Mopar NVG 246 ATF or Equivalent, is there any major difference between the two fluids?
Old Sep 12, 2012 | 06:18 PM
willdikem66's Avatar
willdikem66
Look up what T case you have it wont take 5 sec to find.
And while your searching, search here to find all the prevenative mant. there is a bunch of threads on this that have exactly what to use and how much and how often.
Old Sep 12, 2012 | 10:30 PM
Carnage68's Avatar
Carnage68
Get under the truck, the transfer case has a small metal plate on it with the model of the transfer case. Do not put regular AFT4 in your transfer case if your truck has Auto 4x4. If your not sure, bring your vin to a dealership and they will tell you what you need. Mine has an Auto 4 wheel drive selection and I have an NG 246 transfer case. You can also put in GM Auto Trak II fluid. It is blue in color.
Old Sep 13, 2012 | 08:35 AM
DodgeCares's Avatar
DodgeCares
DJ,
If you want to PM me your Vin I will send you a build sheet which will give you the info you need.
Old Apr 10, 2021 | 08:11 AM
Dustin Blackburn's Avatar
Dustin Blackburn
Originally Posted by DodgeCares
DJ,
I found your thread and wondered if you could locate the information on my truck with my vin? I’m not sure of which transfer case I have either. Thank you.
Old Apr 10, 2021 | 09:11 AM
Go here, feed it your VIN, and it will tell you everything your truck came with from the factory.
Old Apr 11, 2021 | 11:28 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
