Vibration through the gas pedal???
Old Sep 12, 2012 | 08:57 PM
p38251's Avatar
p38251
I run monroe reflex's
Old Sep 12, 2012 | 09:09 PM
MikeHTally's Avatar
MikeHTally
Same here.
Old Sep 12, 2012 | 09:13 PM
kenneymc's Avatar
kenneymc
Same...Monroe Reflex. Real good ride, don't break the bank.
Old Sep 12, 2012 | 09:40 PM
sabin420's Avatar
sabin420
Shocks: I got whatever Tires Plus put on mine. I just had them do it when I was getting new tires.
The vibration could be anything. You have 150K miles so the suspension is getting pretty worn out. Start with the shocks. I wouldn't say it's the rear end unless it was making noise. Basically over the next 50-100K miles you should go ahead and change out bushings, ball joints, wheel bearings, u-joints, Tie rod ends. That will keep your truck riding nice and more reliable. Worn out parts can cause others to wear prematurely. I changed out my shocks around 150K miles along with wheel bearings. I'm at 200K and just now changing out the ball joints and drive shaft U-joints. Next will probably be the tie rod ends. The motor mounts and tranny mount could probably be replaced to help stiffen things up under the hood.
Old Sep 12, 2012 | 09:43 PM
looka's Avatar
looka
Cool, thanks man. Um, this is gonna sound like a total idiot newb question but, what and where are the wheel bearings?
Old Sep 12, 2012 | 09:48 PM
kenneymc's Avatar
kenneymc
In your hubs/knuckles. Let your tires go round n round...lol
Old Sep 12, 2012 | 09:54 PM
looka's Avatar
looka
^ok, so I have to take the hub apart? Also, my front shocks have a spring around them. Does the part I need to buy come with the shock and the spring together?
Old Sep 12, 2012 | 09:57 PM
sabin420's Avatar
sabin420
no, it's just the shock...the spring should last MUCH longer. Oh, rule of thumb for changing shocks. If you hit an average bump in the road (like going over a bridge or something) and your truck bounces more than 3 times, they are worn out.
Old Sep 13, 2012 | 07:43 PM
looka's Avatar
looka
Originally Posted by Dead2Fall
LOL @ this thread... Vibration......
big O.... Wtf lol. Shocks are simple to swap. 30 minute job, if that long. Pretty much four bolts in the rear, the front is a little different, but if you look at it, it's simple.
So, there's struts on the front of my truck and I need a spring compressor to take them off. Or I can just buy the whole strut/spring assembly and do it that way.
Old Sep 13, 2012 | 08:21 PM
MikeHTally's Avatar
MikeHTally
Is it a 4x4? If so, you probably have struts. If not, it's just a shock inside the coil spring. Hell, man. Just get under and look.
