Pinion nut torque help
Old Sep 17, 2012 | 08:50 PM
joebaum's Avatar
joebaum
Default Pinion nut torque help
Can someone please tell me what torque should b on a 9.25 rear pinion nut . Been finding 125 and 210 what's the right torque ?
Old Sep 17, 2012 | 09:11 PM
Dead2Fall's Avatar
Dead2Fall
The right torque was marking it before you pulled it and setting it back exactly how it was + a few degrees. It's responsible for preload, I'm not sure what you would torque it to. Doing a pinion seal, or?
Old Sep 17, 2012 | 09:14 PM
joebaum's Avatar
joebaum
Total overhaul thanks to clips with tru trac but im having a horrible time finding pinion nut torque spec
Dead2Fall's Avatar
Dead2Fall
Ah, thats different.
Old Sep 17, 2012 | 09:18 PM
Dead2Fall's Avatar
Dead2Fall
As Per 04' service manual:
SPECIFICATIONS
AXLE SPECIFICATIONS
DESCRIPTION SPECIFICATION
Axle Ratio 3.21, 3.55, 3.92
Differential Case Flange Runout 0.076 mm (0.003 in.)
Differential Case Clearance 0.12 mm (0.005 in.)
Ring Gear Diameter 235 mm (9.25 in.)
Ring Gear Backlash 0.12-0.20 mm (0.005-0.008 in.)
Ring Gear Runout 0.12 mm (0.005 in.)
Pinion Bearing Preload - New Bearings 1.7-4 N·m (15-35 in. lbs.)
Pinion Bearing Preload - Original Bearings 1-2 N·m (10-20 in. lbs.)
TORQUE SPECIFICATIONS
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Differential Cover Bolts 41 30 -
Bearing Cap Bolts 136 100 -
Ring Gear Bolts 157 115 -
Pinion Nut Minimum 285 210 -
Adjuster Lock Screw 10 7.5 90
Backing Plate Bolts 65 48 -
Pinion Mate Shaft Lock Screw11 8 -
Axle U-Bolt Nuts 149 110 -
Good Luck!
Old Sep 17, 2012 | 09:25 PM
joebaum's Avatar
joebaum
Wow thanks
Old Sep 17, 2012 | 09:29 PM
Dead2Fall's Avatar
Dead2Fall
np bud, had no idea you were in an 04 lol, just looked in my manual for you. Not that it matters really, same axle regardless of year lol
CAUTION: Never exceed the minimum tightening
torque 285 N·m (210 ft. lbs.) when installing the
companion flange retaining nut at this point. Damage
to collapsible spacer or bearings may result.
Old Sep 17, 2012 | 09:43 PM
joebaum's Avatar
joebaum
So 210 ft lbs min and max
Old Sep 17, 2012 | 09:48 PM
joebaum's Avatar
joebaum
I really appreciate u putting all that up there . I have seen many diff torque specs , just makes me crazy . I have my ting gear bolts torqued to 65ft lbs per Yukon manual and it says new pinnion bearing preload of new 14-19 inch
Used bearing 6-9 inch lbs
Old Sep 17, 2012 | 09:53 PM
Dead2Fall's Avatar
Dead2Fall
Yeah I'm not sure what you'd go with using aftermarket parts, but 210 for the pinion nut seems to be the magic number according to our svc. manual. That warning was down a little further in the "replacing pinion seal" section.
