07 Dodge 2500 Lights Problem
Old Sep 20, 2012 | 01:54 PM
btowner920's Avatar
btowner920
Default 07 Dodge 2500 Lights Problem
I have an '07 Dodge 2500 with diesel...the tail lights, rear cab running lights, and both doors courtesy lights are not working. I checked the fuses and all are good.
My question is this...does the control module control this function? If so, is there a problem with using the license plate light circuit for this function since that is working?
Old Sep 20, 2012 | 01:58 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Do you have turn signals? Do your brake lights work?
If so, I would suspect either a faulty headlight switch or a faulty multifunction (turn signal/wiper) switch.
Old Sep 20, 2012 | 02:02 PM
willdikem66's Avatar
willdikem66
Check and move around relays
Old Sep 20, 2012 | 06:28 PM
Dead2Fall's Avatar
Dead2Fall
If you mean splicing into the plate lights to power the taillights I'm pretty sure they already branch off that circuit, maybe not in your 07. I would advise against doing it if it's not. The tipm will probably read it as too high a draw on that circuit and eventually shut it down. Go over your grounds too.
Old Sep 20, 2012 | 06:30 PM
willdikem66
Are you reffering to me?
Old Sep 20, 2012 | 06:53 PM
bestram's Avatar
bestram
mine did the same thing had to replace the fuse box under the hood
Old Sep 20, 2012 | 06:59 PM
Dead2Fall's Avatar
Dead2Fall
No will, op asked about using plate light circuit... He was vague but I think he was asking about powering tail lights with it.
Old Sep 20, 2012 | 08:58 PM
1500hemi4x4's Avatar
1500hemi4x4
i beleave they are all controlled by the tipm totaly integrated power module and no i would not hook them to the licence plate lights as it will more then likly cause more issue's by added more loads/resistence to that circuit
Old Sep 20, 2012 | 09:00 PM
1500hemi4x4
check for output on those circuits out of the tipm if you need a wireing diagram and connector pin out i can post it it may open circuit some wear
Old Sep 20, 2012 | 11:11 PM
sabin420's Avatar
sabin420
check the bulbs first. make sure they are all good and something didn't overload them all causing you not to know if you find the fix.
