RE: ***DIY Transmission Flush***
Old Sep 22, 2012 | 11:56 PM
rgrafton's Avatar
rgrafton
Default RE: ***DIY Transmission Flush***
regarding https://dodgeforum.com/forum/3rd-gen...ion-flush.html
So 20qts of Tranny fluid is all I will need to get most of the 17qts out??
How does the old not mix with the new causing the new to become... well... not new?? A better explanation on how this works would be appreciated. Thanks.
Old Sep 24, 2012 | 11:50 AM
willdikem66's Avatar
willdikem66
It wont thin the New tranny fluid out enough to make it not worth it.
This is why you put more than you need in there.
Old Sep 24, 2012 | 05:37 PM
p38251's Avatar
p38251
The extra couple of qts gets out majority of the old fluid, what little is left won't hurt anything. This proceedure is very close to using a fluid exchange machine, which does the same thing, puts in some new, takes out some old until its cycle is completed. DD proceedure actually sounds better, and gets more of the old fluid out.
Old Oct 4, 2012 | 09:46 PM
mmike1's Avatar
mmike1
so you put the return line and the new hose that you added, into the bucket
