hesitation problems
Old Sep 24, 2012 | 02:30 PM
santni19's Avatar
santni19
Default hesitation problems
i have a 03 dodge ram 2500 with a 5.7 hemi has a hesitation when gassing it got better when i cleaned the throttle body then came back did this twice both times it got better and came back also changed map sensor there is not a check engine light on please help
Old Sep 24, 2012 | 04:13 PM
willdikem66's Avatar
willdikem66
Start with a tune-up spark plugs etc etc.
Re grounding your TB would help
you dont have a egr so check the pvc make sure thats clean and moving.
No codes? But you changed the MAP..... you might as well just change the o2 sensors too if you are over 100k(Im not saying they are the problem but since you put one sensor on might as well do another).
Old Sep 24, 2012 | 04:29 PM
santni19's Avatar
santni19
Default code
originaly i had po 113 so i did map sensor but didnt make a differance and light never came back on
Old Sep 24, 2012 | 05:02 PM
willdikem66
Well the P0113 is the IAT code not the MAP sensor.
Old Sep 24, 2012 | 05:18 PM
santni19's Avatar
santni19
Default iat
thanx for replying were and what is iat
Old Sep 24, 2012 | 05:24 PM
p38251's Avatar
p38251
Inlet air temp. Located in the tube going from your air box to the throttle body. Agreed on tune-up. Run some sea foam in a full tank of fuel, will clean up the injectors.
santni19's Avatar
santni19
Default iat
would a bad iat give it a hesitation
Old Sep 24, 2012 | 05:33 PM
willdikem66
Yes it could give it hesitation.
Old Sep 24, 2012 | 05:42 PM
p38251's Avatar
p38251
The PCM uses it for fuel management. It can take or add fuel depending on what temp it sees.
