Old Aug 10, 2015, 04:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Parking and fog lights won't turn off
Old Sep 28, 2012 | 08:59 PM
iDodge's Avatar
iDodge
Unhappy Parking and fog lights won't turn off
I have a 2003 dodge ram quad cab 1500 4.7l v8. One day i turned on both my lights and my fog lights (yes it was foggy) and when i got out and turned them off the dome lights stayed on along with the parking and fog lights, and that annoying dinger wouldn't turn off, and the weird thing is my main lights will turn on and off! So i pulled the fuses for the fog and parking lights and just been riding around with my lamp lights on and every time i open the door the dinger stays on. I turned on all the lights and pulled the plug out of the switch and the still are staying turned on.
I THINK MY RAM IS HAUNTED. PLEASE HELP
Old Sep 28, 2012 | 10:07 PM
broggyr's Avatar
broggyr
It could be a bad switch...
Old Sep 29, 2012 | 08:06 AM
Gone Fishin's Avatar
Gone Fishin
You might try reseting the computers, the FCM (front control module) operates all the stuff giving you problems. Its a good place to start. You may want to download the FSM from Weedahoe, its in his sig, first and study up on the circuit arrangement ahead of time. You should also check for any dtc codes BEFORE you reset the computers, they don't always turn on the MIL light. Record any codes prior to the reset, so you have somewhere to start, the dtc codes are also in the FSM in the back-------and its FREE!
Old Sep 29, 2012 | 12:32 PM
Dead2Fall's Avatar
Dead2Fall
stuck relay?
Old Sep 29, 2012 | 03:55 PM
HammerZ71's Avatar
HammerZ71
I'm thinking under the fuse box is corroded. Common as these trucks age...
Old Oct 8, 2012 | 12:18 PM
Tread70's Avatar
Tread70
Most likely its the switch, I had that happen on my 02.
Tread
Old Oct 8, 2012 | 02:37 PM
willdikem66's Avatar
willdikem66
Looking at the Fuse box under the Hood like Hammer said look underneath that for corosion, I had a Realy screw up on me and i had a similar problem, and last but not least id look into getting a new switch( My fogs would randomly come on i took the switch apart and cleaned it fixed that ONE problem)
