Lash Adjusters install/replacement help!!
Old Oct 6, 2012 | 03:39 AM
elainenseth's Avatar
elainenseth
Default Engine Noise - Timing Belt? and/or Lifters/Lashadjusters!!!
I started changing the lash adjusters last night, but now im reading on top of letting them sit in oil for a while prior to install you are also supposed to prime them?
Also having trouble getting the millertool to work on the last 2 valves.
Any help would be appreciated.
The new lash adjusters will not depress but neither will the old ones i took out so far. I was reading that you have to stick a paperclip in them to prime them?????
UPDATE: I changed the lash adjusters on passenger side but the noise is still very prevelant.I am starting to think it is the timing belt making the noise I took a couple videos maybe someone can chime in and tell me what they think the noise is. Engine has 279,000 miles on it. 4.7L 2005
Timing Chain loose???? or normal???
http://www.youtube.com/watch?v=A2v9P...ature=youtu.be
Engine running with passenger side valve cover off.
Old Oct 6, 2012 | 08:37 AM
swanner's Avatar
swanner
Sounds like my 02 4.7, mine was stupid exhaust manifold bolts and bad gasket,
In regards to the timing chain?? Hmm. Looks a little loose, any speecs on chain slack play? Or tension play
Old Oct 8, 2012 | 08:53 AM
elainenseth
bump!
Drove the truck about 9 hours this weekend it drives great but i need to fix that noise, anyone have any ideas?
I'm stuck, lash adjusters did not seem to help.
Old Oct 8, 2012 | 11:15 AM
willdikem66's Avatar
willdikem66
I would look up specs on that timing chain
