Hemi shuts off when cold
Old Oct 7, 2012 | 07:08 PM
Dragonrep's Avatar
Dragonrep
Default Hemi shuts off when cold
I have a 2006 Megacab Hemi auto trans that occasionally shuts off when the engine is cold. It doesn't happen all the time, and only when the engine had been running less than 3 or 4 minutes.I am thinking the EGR valve is bad, any other suggestions? If not, has anyone replaced replaced one yet?
Old Oct 7, 2012 | 07:26 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Any CEL on? Have you check for any codes?
Old Oct 8, 2012 | 11:06 AM
willdikem66's Avatar
willdikem66
Yep first things first any CEL. Have you checked you EGR if you suspect it?
Old Oct 8, 2012 | 01:00 PM
broggyr's Avatar
broggyr
When you say it shuts off, does it just stall? Or is it like someone's turning the key off (losing ignition)?
Old Oct 10, 2012 | 06:46 PM
Dragonrep's Avatar
Dragonrep
No cel lights, nothing in the computer. When it shuts off it is a stall, everything else works, just no go. Put it in park, it generally starts right up. Every once in a great while it is a hard start, cranks a few seconds longer, but it always starts. O2 sensors test good through the computer too, no out of the ordinary odors form the exhaust, and none from the intake.
Old Oct 10, 2012 | 08:01 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I know it might sound silly but have you properly checked the level of the trans fluid? It it is low, sometimes it will cause a stall like that.
Old Oct 13, 2012 | 11:25 AM
Dragonrep's Avatar
Dragonrep
I checked the trans fluid this morning. The level looks fine,though I know it is need of flushing due to mileage. It looks good on the dipstick, nice and pink, no unusual odors there either.
