Trouble Idling After Dead Battery
Old Oct 10, 2012 | 01:44 AM
JimLewis's Avatar
JimLewis
Default Trouble Idling After Dead Battery
I've owned 2 GEN2 Dodge Rams and 1 GEN3 Dodge Ram (pictured below). And they've all had the same problem. Whenever I run my battery all the way down by accidentally leaving something on or plugged in then after I jump start it and get it running, I have to power-break every where I go for the next half hour. That is, I have to ride the throddle whenever breaking, otherwise the engine dies. It will not idle automatically.
Somehow, after about 30-45 minutes of doing this, the electrical system starts working properly again and the truck re-learns how to keep an idle. Then I'm fine, as long as I don't run down the battery again.
But this is pretty stupid. I own 14 other non-Dodge Trucks and SUVs and none of my other vehicles have this problem. Why does this happen and is there a solution to this? Someone suggested a backup battery that just keeps the electrical system 'memory' in tact if the main battery dies. I have no idea what that involves but this has happened enough times that it's starting to get annoying. I'd love to figure out a way around that.
I should be able to jump start the vehicle and then drive it around town without it dying on me ever 5 seconds, shouldn't I? There must be an easy solution for this.
Old Oct 10, 2012 | 04:57 AM
bwdakrt's Avatar
bwdakrt
Normal for the Dodge trucks. Until the alt gets the charge in the battery built back up to 12 volts they do not like to idle. Has nothing to do with the PCM...just the nature of the beast.
Old Oct 10, 2012 | 09:08 AM
broggyr's Avatar
broggyr
Originally Posted by JimLewis
Why does this happen and is there a solution to this? ... There must be an easy solution for this.
The easy solution is to not let your battery run down.
The only other way is to install some sort of battery backup to maintain power to the computers so they don't forget their settings.
For some reason, I didn't see this until just now. I suppose my reading comprehension needs a swift kick in the **** lol
Old Oct 10, 2012 | 03:44 PM
07Chuck's Avatar
07Chuck
Default Overworked
Find a way around it? Why? Does this happen to you a lot? Just my opinion here but that battery will be junk in no time if it keeps getting deep cycled and it's always best to fully charge it if you can so you don't overwork your alternator
Old Oct 10, 2012 | 03:48 PM
07Chuck's Avatar
07Chuck
Default Overworked
Just my opinion here but that battery will be junk in no time if it keeps getting deep cycled and it's always best to fully charge it if you can so you don't overwork your alternator I saw a on board charger/tender at Napa recently you just hook two eyelets to the battery then plug er in.
