2004 Dodge Ram 1500 V8 Hemi - Squeeking & Vibrations
Old Oct 11, 2012 | 10:12 PM
tazzman0001ca's Avatar
tazzman0001ca
Post 2004 Dodge Ram 1500 V8 Hemi - Squeeking & Vibrations
Can anyone offer me any advice or suggestions on this? While I am driving my truck, there is consistently a squeeking sound and vibration from high speeds to low speeds. It can't just be my brakes, because this happened even after I had them done. Would I have to put all new calipers and hoses on too? Would that solve my issue? Is it something else that I am missing? Any advice is appreciated! Thanks.
Old Oct 13, 2012 | 11:56 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
When you did your brakes, did you have the rotors turned or replace them? If they are warped then the high side could make slight contact with the pads giving off a noise. Also, if they are warped, they would not be balanced and give a vibration from the rotating mass being off.
Old Oct 13, 2012 | 04:33 PM
sabin420's Avatar
sabin420
Possible U-joints on the drive shaft. Worth checking into.
Old Oct 14, 2012 | 10:02 PM
p38251's Avatar
p38251
where is the vibration. steering wheel when braking? agree with u=joint they will squeek when they get really bad.
