is it an alt problem??
Old Oct 12, 2012 | 08:42 PM
dratomic's Avatar
dratomic
I went to autozone and they said the batt and alt are good? And i checked all the grounds and no corrosion or anything. Idk what else to look for
Old Oct 12, 2012 | 10:33 PM
willdikem66's Avatar
willdikem66
Hmm check the Neg ground that grounds the ground.
I cant remember exactly where it is.
Thats not sarcastic btw
Old Oct 13, 2012 | 10:15 AM
kenneymc's Avatar
kenneymc
Did you take the connections for battery, and grounds apart and clean them? Or just look at them? Cleaning and reseating stuff sometimes will fix things like this. Make sure they are good and tight too. May want to get a second opinion on batt and alt. Other than that and that point in the thread I posted, not sure what else to tell you. Could try reseating fuses.
Old Oct 13, 2012 | 11:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I had a battery once that I had checked. One store checked it and said it was good, another said it was bad. Guess who I bought a battery from? I already KNEW I had a bad battery but the store it was under warranty from said it was good.
Old Oct 13, 2012 | 08:48 PM
willdikem66
Thats just sounds like typical chain parts stores
