Body lift and tire q's
Old Oct 14, 2012 | 09:00 PM
Bosox93's Avatar
Bosox93
Default Body lift and tire q's
I'm looking at putting a 3in body lift on my truck, i was wondering if a 37x13.5r17 would fit? I'm pretty sure a 37x12.5r17 would fit, wasn't sure about a little wider tire. I was also told with 37's I should be changing the gears or I will blow up the tranny, just wondering if that is true. I've pretty much narrowed it down to either the nitto mud grappler, goodyear mud tire with Kevlar or the Mickey Thompson mtz tire, does anyone have anythoughts on these tires or a suggestion on a different one, I would like one that does good in snow.
Old Oct 14, 2012 | 09:27 PM
Nate_sorenson's Avatar
Nate_sorenson
aftermarket rims? also mud graps will go bald in like 20k get some trail grapplers they are agressive as hell but wont howl nearly as much on the road. post a pic when you do it, your proboably going to have to level aswell. just for bigger tires its not gonna be worth gear change especcially if you own a 4x4 which would mean 2 times the labor and two sets of master install kits and the gears themselves. also diff fluid is expensive. not being a downer but with mud tires and a body lift you will get laughed at. good luck and post pics if you go down this road. oh and we have a sticky thread for this
Old Oct 15, 2012 | 12:00 AM
08HEMI1500's Avatar
08HEMI1500
Yea since you're just getting a BL it's safe to assume you won't be offroading since that's probably the worst way to get clearance for bigger tires. If it's only gonna be on road then stick with 35s as your MPG will tank with 37s. Will they fit? Probably but you may rub especially without a level in addition to the lift. But definitely go with the Trail Graps since you'll get longer life out of them or the Mickey Thompson's if you're will to dish out for them
Old Oct 15, 2012 | 07:35 AM
Bosox93's Avatar
Bosox93
It does have a leveling kit in it now and 35in pro comp tires, I just figured since I was going to lift it I might as well put bigger tires on it. Have you owned the trail Trappists before? Are they any good on snow or ice? It also has eagle rims on it, I'm not sure on the width or backspacing because they were on the truck when I bought it. Thanks for the suggestions.
Old Oct 15, 2012 | 07:36 AM
Bosox93's Avatar
Bosox93
Trail grapplers, sorry auto correct.
Old Oct 15, 2012 | 01:28 PM
08HEMI1500's Avatar
08HEMI1500
I personally don't have experience with them but I've read a number of reviews on here as well as other site to lead me to believe they are a great tire. As for snow I have no clue but while mud tires are good on snow they are terrible on ice
Old Oct 15, 2012 | 01:34 PM
willdikem66's Avatar
willdikem66
Exactly lol
Old Oct 15, 2012 | 06:12 PM
Bosox93's Avatar
Bosox93
Thanks for the suggestion, I like the look of the trail grapplers to, I'm going to a 4x4 shop this weekend an I'll see what they suggest. I'm defiantly leaning towered that trail grapplers now.
Old Oct 15, 2012 | 09:33 PM
Nate_sorenson
Good choice, don't mean to come off negative or mean on my first reply lol. Anyone know the treadlife of trail graps
Old Oct 15, 2012 | 10:20 PM
Bosox93's Avatar
Bosox93
It's no problem, if I had the money I'd be doing a suspension lift but with the prices of tires I can't get both.
