bigger tranny cooler???
Old Oct 20, 2012 | 08:09 AM
jj141979's Avatar
jj141979
Default bigger tranny cooler???
I have a 2003 ram hemi 1500. I want to put a larger tranny cooler in it. I'm having trouble locating one. I need some part numbers for it. I'm assuming it would be a cooler from a 2500 or 3500. Would this work???..... http://www.etrailer.com/Transmission-Coolers/Dodge/Ram+Pickup/2003/D13504.html?vehicleid=2003750648. Also would a ctd cooler work??
Old Oct 20, 2012 | 08:19 AM
AZZO540's Avatar
AZZO540
checkout summitracing.com
Old Oct 20, 2012 | 09:49 AM
willdikem66's Avatar
willdikem66
Make sure you know the exact one you want. They have some options, Also try craigslist. Or Stealership
Old Oct 20, 2012 | 11:40 AM
abarmby's Avatar
abarmby
Some 03 Hemi's (like mine ) came with a larger tranny cooler from the factory.
Have you checked to make sure yours hasn't already got it?
Here's a pic of mine which shows the larger tranny cooler in front of the main engine rad. It's a 26 row cooler I believe?
Hope this helps?
Al.
Old Oct 20, 2012 | 11:48 AM
jj141979's Avatar
jj141979
Hope this helps?
Al.
Nope. I got the smaller cooler. I want that cooler! Ill trade ya! Lol! Is your truck a 1500? Do you know the part#? Thanks!
Old Oct 20, 2012 | 11:49 AM
abarmby's Avatar
abarmby
To the OP. Look at this thread on the board and item marked 2 in red is the stock size tranny cooler.
As you can see....my heavy duty Tow package cooler is a lot bigger.
Al.
Old Oct 20, 2012 | 12:06 PM
jj141979's Avatar
jj141979
Al.
Yeah, I know. I want the cooler u have! Do you know the part #? Is ur truck a 1500, 2500, or 3500?
Old Oct 20, 2012 | 12:10 PM
SLT8's Avatar
SLT8
52029089ab
Old Oct 20, 2012 | 12:47 PM
HammerZ71's Avatar
HammerZ71
You'd actually do better by going to a larger pan (MagHytec or PML) which allows for the use of more fluid - plus they are made of better cooling material and have cooling fins...
Old Oct 20, 2012 | 12:51 PM
jj141979's Avatar
jj141979
Originally Posted by SLT8
52029089ab
Thanks!! I'm finally getting somewhere!
