02 ram 1500 bad fuse box??
Old Oct 22, 2012 | 09:19 PM
mrkeru's Avatar
mrkeru
Default 02 ram 1500 bad fuse box??
My headlights work and the brake lights, all turn signals. My rear tail lights do not work when headlights are on and neither do the parking lamps. The fuse is good (replaced it) the relay is good. I hear the fuse box ( ipm ) goes bad. I cant afford to spend almost $800 right now to get it replaced. Is there an easy fix for this problem that will get me by till I can spend the money on a new fuse box?
Old Oct 23, 2012 | 03:38 AM
abarmby's Avatar
abarmby
Yeah there is.
I can't find the threads at the moment that show you how to do a temporary jumper to check that it is your fuse box, as I'm using my phone.
There is also a step by step with pictures "fix", by soldering new connections on the internal printed circuit board floating about.
If you do a search.... There are numerous posts about this problem.
Al.
