Rod knock or Manifold Leak on 4.7l 2005
I just finished doing my timing chain and lifters and my truck is pretty quite now however i can still hear a faint noise. The truck has 280,000 miles on it.
I purchased the oil pan gasket when i did the timing chain, thinking i would need to remove to replace oil pump however that was not necessary.
I still plan on removing the oil pan gasket shortly to remove any old broken timing gear plastic parts etc. I was wondering if it is possible to replace the rod bearings if their is play while still in this engine?
I am also going to replace the manifold gaskets as I see a head missing hear and their in the rear of the manifolds.
Any other possibilities that might help without removing the block?
