cruise not working!!
Old Oct 30, 2012 | 12:29 PM
plowhammer's Avatar
plowhammer
Default cruise not working!!
2002 Dodge Ram cruise not working and air bag light is on! Any suggestions?
Old Oct 30, 2012 | 07:38 PM
Denniss66's Avatar
Denniss66
Figure out the air bag light once in a while my air bag light comes on and the abs light and cruise then stops working
Old Oct 31, 2012 | 12:19 PM
HemiLonestar's Avatar
HemiLonestar
Codes?
Old Oct 31, 2012 | 01:46 PM
p38251's Avatar
p38251
Could be bad LF wheel bearing. More specificaly the speed sensor is bad.
Old Oct 31, 2012 | 04:06 PM
Wilson01960196's Avatar
Wilson01960196
It could be a bad clockspring in ur steering column
Old Oct 31, 2012 | 05:58 PM
plowhammer's Avatar
plowhammer
No there are no codes or check engine light thought that was kinda weird!
Old Oct 31, 2012 | 07:37 PM
Kscha41's Avatar
Kscha41
Im thinking the same. When they go bad, most of the time the air bag light is on. At the same time you lose your horn and I would think your controls for the cruise could stop too.
Old Oct 31, 2012 | 08:14 PM
Wilson01960196
Normally when they go bad ur airbag light will come on for small intervals and overtime get worse..in someit cases peiple have saidu their abs and brake light came onon and ur cruise willu not work at all or work at random speeds like 40-45it and 70-75mph..mine is bad right now and i believe parts and labor is around 300$ at the dealer
Old Nov 1, 2012 | 12:06 PM
plowhammer's Avatar
plowhammer
Horn works fine just the cruise, the light doesn't even come on! Would think that all three would not work if it was clock spring! Air bag horn and cruise controls!
