Ram won't start
Old Dec 10, 2012 | 05:53 PM
  #21
xiskids's Avatar
xiskids
all dealer said on service report was "possible internal motor damage"
didn't give me any codes
i did change the oil and it felt clean,didn't feel anything(i rubbed my fingers through oil)
will try new sensor in a few days(when weather warms up a bit)
thanks wil let you know
Old Dec 10, 2012 | 07:41 PM
  #22
66three83's Avatar
66three83
I don't understand. You pulled the old one out, and didn't take another few minutes to replace it?? I would be dying to know if that was the problem!!!
Old Dec 11, 2012 | 09:17 AM
  #23
Izero's Avatar
Izero
I am curious where the "metal shavings" are from exactly...
Old Dec 11, 2012 | 02:26 PM
  #24
xiskids's Avatar
xiskids
metal shavings were on/around sensor, at the tip back about 1 inch
real fine ,small, pieces
Old Dec 11, 2012 | 02:29 PM
  #25
xiskids's Avatar
xiskids
saw the shavings around sensors and figured there was something definitely wrong so didn¨t bother trying new 1
Old Dec 11, 2012 | 02:54 PM
  #26
Izero's Avatar
Izero
"Around" meaning outside of the part of the sensor that makes contact with the cam or inside?
Old Dec 11, 2012 | 06:50 PM
  #27
xiskids's Avatar
xiskids
when you pull sensor out,metal shavings were on the end of the sensor,which sits inside motor
put new sensor in
new oil and filter was already added
should i add 2 quarts extra ? (and what does that do ?)
will be trying to start it tomorrow (wednesday)
thanks again
Old Dec 12, 2012 | 08:45 AM
  #28
Izero's Avatar
Izero
NO DO NOT "ADD 2 EXTRA QUARTS"!!!!
Just leave the drain plug off and pour two quarts in and let it drain out before closing it up and filling it up with 7 quarts.
NEVER OVERFILL YOUR OIL!
Old Jan 14, 2013 | 09:37 AM
  #29
Forge's Avatar
Forge
So what happened?
Old Jan 14, 2013 | 04:15 PM
  #30
Ryan.lee25's Avatar
Ryan.lee25
I actually am having the same issues. I just bought a new crankshaft position sensor this weekend because its so freakin' cold here, its getting installed at a shop right now. I will let you know who it goes, but I would go down that road also.
