My truck is higher on one side
Old Nov 8, 2012 | 07:30 PM
sabin420's Avatar
sabin420
Take the suspension apart and check each part. I think it's the shocks. They can wear out without showing signs of wear. My basic test for shocks without removing them is when you hit a bump or go over railroad tracks or something, If the truck bounces up and down more than 3 times, it's time for new shocks.
Old Nov 8, 2012 | 09:02 PM
MoparPaul's Avatar
MoparPaul
Originally Posted by team_realtree
What would I check to be worn? I also have lift blocks, lift spindles, and upper and lower coil spacers.
I would be willing to bet the coil spacers are to blame... especially if they're made or polyurethane.
Old Nov 8, 2012 | 10:13 PM
08HEMI1500's Avatar
08HEMI1500
What's an upper and lower coil spacer? Lol
Old Nov 9, 2012 | 08:24 AM
team_realtree's Avatar
team_realtree
Just like it sounds, one mounts on top of the coil one mounts under. Upper is a 1.5" daystar and the lower is a 1.5" top gun customs off eBay. The lower one is metal the upper is poly. Wouldn't recommend this setup to anyone though the spring is very compressed and the ball joint angles aren't ideal. I put the swaybar on yesterday and it evened it out to probably 1/4 inch in the front still way off in the back..gonna try switching shocks left to right in the rear.
Old Nov 9, 2012 | 08:48 AM
mantisman51's Avatar
mantisman51
Just let half the air out of the the tires opposite the saggy side, and voila! Fixed.
mantisman51
That's a joke right there. Probably a worn out component as mentioned-shock or spring or something.
Old Nov 9, 2012 | 09:21 AM
Bob5151's Avatar
Bob5151
2nd Gen. Rams are known for sagging on the driver-side. Between the driver seat seeing more weight more often (obviously), the battery, and the gas tank, they are known for simply wearing out the springs on the driver side.
Old Nov 9, 2012 | 11:45 AM
08HEMI1500's Avatar
08HEMI1500
Never heard of a lower coil spacer but whatever you say chief. Definitely sounds like a dumb way to lift a truck though
Old Nov 10, 2012 | 09:55 AM
team_realtree
It's no different than putting a spacer on the top your still applying force to spread the upper and lower control arms apart. Apparently things you haven't heard of are dumb?
