wheel bearing 04 ram 2wd
Old Nov 7, 2012 | 03:06 PM
CatLover's Avatar
CatLover
Default wheel bearing 04 ram 2wd
Hello all. I think i have a front wheel bearing problem.
2004 Ram 1500 Hemi, 2wd, 4wabs.
I plan to jack it up and spin it later to confirm, but my questions are these:
Opt1. replace the hub assembly. looks like TIMKEN Part # SP500100 at Rockauto ~ $131?
Opt2. replace the bearing. can one remove the damaged bearing without a press? Also, can the new bearing be installed in the original hub without a press? Also, is it worth trying to keep the factory hub?
https://dodgeforum.com/forum/1st-gen...l-bearing.html
It seems that years (decades) ago I was able to replace my jeep axle bearing with a rubber mallet and a beer can...any tricks like this for this situation? I'm always up for emptying beer cans.
Thanks in advance.
Old Nov 7, 2012 | 03:44 PM
Gone Fishin's Avatar
Gone Fishin
UUUUUUUUUUUUhhhhhhh------no! Option one is your only real option, You'll spend more time trying to fix the old one that just biting the bullet and replace it. Just make sure you get the one with the abs sensor in it. Might not be a bad idea to do both, and pads if you need them, you'll be in there anyway!
Have Fun!!!!
Old Nov 7, 2012 | 04:52 PM
Bigboytoys's Avatar
Bigboytoys
Agreed...Did mine 10K miles ago...Definately get the ones with the ABS sensor. Makes life a HELL of a lot easier!
Old Nov 7, 2012 | 05:33 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I bought new wheel bearing hub assemblies some time back off Ebay brand new with ABS sensors for about 65 shipped I think.
Old Nov 8, 2012 | 09:13 AM
HemiLonestar's Avatar
HemiLonestar
Lots of PB blaster or WD40 and a BFH.
Old Nov 8, 2012 | 06:20 PM
CatLover's Avatar
CatLover
I put it on a jack today and the front left felt a little weird. It spun ok, but made a slight grinding noise. I squeezed the caliper and it spun the same. there was very little if any play as I attempted to rack the tire/wheel back and forth.
For grins i jacked up the right front, did the same spin, and it was a little worse/more grindy, and felt like a small amount of slop when i racked the wheel/tire back and forth.
I drove for about 10 minutes in town and the lugs on both sides felt pretty hot.
I remember driving through a 18"deep puddle at the coast last weekend. now i think at 117k mi. they were close to the end of life...then under water briefly...then 4 hours on the highway home may have ruined them both.
I'm going to go drive some more.
Q: did i read somewhere that the caliper bolts = 80 lbs, mounting bolts 180lbs?
Thanks
