headlight problem
Old Nov 12, 2012 | 10:39 AM
hopej's Avatar
hopej
Default headlight problem
I have a 08 ram 1500 just put hid kit on truck it is 55w with cannibus and on low beam it will cut on and off but doesn't do it on high what do I need to do to fix that
Old Nov 12, 2012 | 11:12 AM
jrm747's Avatar
jrm747
https://dodgeforum.com/forum/3rd-gen...k-in-here.html
Old Nov 12, 2012 | 11:50 AM
Izero's Avatar
Izero
lol Cannibus... Canbus***
You should read the thread that jrm747 posted, as you might still need the load resistors and some other things, you should also double/triple check your grounds and make sure you're getting good contact to ground.
Could be a million things causing that problem, so you have to go get your hands dirty.
Old Nov 18, 2012 | 05:00 PM
inktoxicated's Avatar
inktoxicated
i tried installing mine the other day. what a mess. either returning or selling and buying brighter halogens. to much of a headache for headlights.
Old Nov 18, 2012 | 05:04 PM
inktoxicated
izero where in jersey u at?
Old Nov 19, 2012 | 08:17 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Not a mess. Quite simple actually. As long as you are educated and understand why/how they work.
