fog lights hid
Old Nov 14, 2012 | 09:00 AM
hopej's Avatar
hopej
Default fog lights hid
08 ram 1500 want to get hid fog lights what all do I need and I need the wiring harness switch and fog lights assembly do they just plug into socket or do u have to buy harness and ballast like headlights
Old Nov 14, 2012 | 09:33 AM
Albertaramfan's Avatar
Albertaramfan
I'm not sure I understand wether you currently have foglights or not so I'll list it all (that I can remember)
You will need
HID kit
Fog light housings
Wiring harness
Foglight capable headlight switch
The Hid kit will just be plug and play. I bought the digital balasts for mine and am very happy with them
Old Nov 14, 2012 | 05:24 PM
Brandon Anderson's Avatar
Brandon Anderson
Do you already have fog lights? If not, what model do you have (ST, SLT etc)?
Old Nov 14, 2012 | 05:46 PM
hopej's Avatar
hopej
St model don't have any at all
Old Nov 15, 2012 | 07:42 PM
Brandon Anderson
Check under your bumper, near the fog light holes, and see if you have open connectors hanging there. If you do, this upgrade will be a little easier for you. If not, may be better to get aftermarket fogs.
Old Nov 15, 2012 | 07:51 PM
Nate_sorenson's Avatar
Nate_sorenson
assuming you have stock fogs then all you need is a 9006 bulb size hid kit, don't get a 35watt ballast, they suck. Look into digital 50w with relay. Are fogs are not CANBUS so you don't need resistors or any of that crap, simple plug and play
Old Nov 18, 2012 | 04:52 PM
inktoxicated's Avatar
inktoxicated
i just installed a kit from extrahid.com 35w 8000k in fogs so much room under there to work and mount the ballasts. no harness needed just plug and play. unforutnaly the ballasts in the kit supplied were chinesejunk and the 8000k was more like 10000k and ridiclously blue. took them out
Old Nov 19, 2012 | 08:19 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I havent seen any ballasts that were made in the USA. Not even OEMs on cars that came with them are USA made.
If you didnt like the 8k bulbs then just go to 6k. Thats all I use. I would rather see where Im going than for people to see my blue lights
Old Nov 20, 2012 | 08:44 AM
Izero's Avatar
Izero
Japan makes the best ballasts around...
My favorite HID website is:
http://www.theretrofitsource.com/
Enjoy
Old Nov 20, 2012 | 08:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
TRS isn't far from me and I've ordered several things from them before. They always have good quality gear but at the same time, I have used very cheap components for other guys builds who were on a budget and they are still kicking.
In fact, I have a case of Morimoto 2.8" projectors and shrouds sittings and 4th Gen (micro) ballasts.
