What causes the "ticking"/Looking to fix mine.
Old Nov 15, 2012 | 03:03 PM
GRNDPNDR's Avatar
GRNDPNDR
Default What causes the "ticking"/Looking to fix mine.
I've got a ticking going on in my engine and I'm looking at getting the parts to fix it up, but I'm not sure which parts cause this particular problem.
Mine isn't just happening on startup, it happens all the time and is relative to RPM. I've read a bit about it and it seems the 4.7L engines suffer from this problem commonly.
I'm hearing possibly two noises though, the ticking that is noticeably loud at all RPM ranges, but is kind of intermittent at idle, and then there what sounds like more of a quiet knocking noise that I can only hear at idle because it's so quiet.
So to sum it all up, Do I need to purchase/replace the lifters to cure the ticking noise? And how can I diagnose this "knocking" noise I hear? is it possible that it's just another lifter but with less of a problem?
Here is a video I got today....not that the video is useful, but the sound is
http://www.youtube.com/watch?v=PJBz9...ature=youtu.be
Old Nov 15, 2012 | 04:29 PM
cullyboy87's Avatar
cullyboy87
one way to narrow it down is crawl up in the enine bay with a long hanled flathead and put the bit end on a valve cover annd the other to your ear and move it around the valve cover to see if one lifter is ticking louder tha the other, repeat on the other side. isnt scientific, but ive figured out a many lifter issues using this method. also try running a lil thicker oil or diesel oil as it has stuff in it that gasolone oils dont.
Old Nov 15, 2012 | 06:58 PM
GRNDPNDR's Avatar
GRNDPNDR
I have a mechanics sthescope, When I checked the drivers side valve cover the sound seemed to be equally as loud across the entire cover.
The passenger side was quiet, except that I could hear the noise as if it were "far away"
I don't hear much of anything from the oil pan.
Old Nov 15, 2012 | 10:44 PM
cullyboy87's Avatar
cullyboy87
if you can, put it on the side of the head itself and move from front to back, and if you have to, ask somebody to get inside and rev it up to about a grand to make the sound more distinquised.If its just intermitent at idle and always there when the engine is above idle, it soulds like somewhere isnt as getting as much oil as it should. have you looked around at something that could be vibrating or is it so obvious that you know its coming from the direction of the motor? just throwin that out there.
Old Nov 15, 2012 | 10:49 PM
IamFrank's Avatar
IamFrank
I'd start with the cheaper, less intrusive possible fixes first before going after the valves. Try doing each of these in this order until the noise goes away. Do not do more than one of the additives at a time. Use one, then let it run its cycle and if it does not work, move on to the next.
1. Sea foam
2. Lucas upper cylinder lubricant
3. Lucas Oil Stabilizer
4. Check EGR valve
5. Check exhaust manifold bolts
6. Check valves
7. Check pistons
Old Nov 16, 2012 | 08:27 AM
GRNDPNDR's Avatar
GRNDPNDR
1. Sea foam
4. Check EGR valve
6. Check valves
7. Check pistons
I've put 3 cans of seafoam into her, 1 in the tank, almost 1 in the crankcase, and the rest through the brake booster line.
Intermittent.....this is basically what it sounds like...
tick tick tick tick tick (silence) tick tick (silence) tick (silence) tick tick tick tick (silence) (silence) tick tick .....
with the sounds happening once or twice per second.
Old Nov 16, 2012 | 10:51 PM
IamFrank's Avatar
IamFrank
Originally Posted by GRNDPNDR
Intermittent.....this is basically what it sounds like... tick tick tick tick tick (silence) tick tick (silence) tick (silence) tick tick tick tick (silence) (silence) tick tick .....
This sounds exactly like what a busted exhaust manifold bolt would do. If it were the lifters, valves, or pistons, the sound would be more consistent. You may want to consider taking her to an exhaust shop and have them check the manifold bolts out.
Also, change the oil if it still has the seafoam in it. Its job is to dislodge and dissolve carbon so even if it did not fix the tick, it still muddied up your oil and should therefore be changed. The fuel tank and lines will burn it off but the crankcase will hold it.
Old Nov 16, 2012 | 11:32 PM
looka's Avatar
looka
Yep, I'd put my money on broken exhaust manifold bolts. From what I understand it's a relatively simple fix. You gotta remove the fender wheel wells and then you'll have access to them.
Old Nov 17, 2012 | 09:25 AM
GRNDPNDR's Avatar
GRNDPNDR
I'm not going to say it's not a manifold bolt, but I do have my doubts about that. The sound just doesn't seem to be emanating from the exhaust manifolds.
Old Nov 17, 2012 | 05:36 PM
GRNDPNDR's Avatar
GRNDPNDR
Added a video to the first post
