Window only works from driver side
Old Nov 20, 2012 | 05:36 PM
Ruddigger's Avatar
Ruddigger
Default Window only works from driver side
I know there are lots of posts regarding this issue, however, I am stumped. I have an 04 Ram 1500 4x4 quad cab, My problem: Windows will only operate from the drivers master control. I have taken the following actions to try and correct the problem
1. Cleaned and greased the window lock switch
2. Re-soldered the window lock pins as mine were cracked as seen in some of the posts
3. tried to bypass the window lock by connecting the orange/light blue wire with the main power wire (yellow and pink)
4. bought a new master control unit
After all of these steps my windows will still only work from the drivers control. If i am rolling the other windows down or up using the drivers switch and try to use the passenger switches at the same time the windows will stop moving so I believe that they are getting some sort of signal but I am stumped as to what I can look for next. Can anyone throw some suggestions this way I don't care if i cannot lock the windows anymore just as long as the passengers don't have to bother me to roll down their windows for them
Old Nov 21, 2012 | 04:04 AM
abarmby's Avatar
abarmby
I had a similar thing and it turned out it was one of the main harness plugs going into the back of the driver master control panel.
If I wiggled the harness, the windows would work.
I tightened up the connectors by opening the pins up with a small screwdriver in them.
Just very small amounts and then an electrical solvent spray clean.
Job sorted :-))
Old Nov 21, 2012 | 03:20 PM
DodgeCACares's Avatar
DodgeCACares
Ruddigger,
Let me know if Abarmby's suggestion solves your problems. If you have additional inquiries feel free to PM me. I can review your VIN# to see if there is any further assistance I can provide.
Old Nov 22, 2012 | 12:11 AM
Ruddigger's Avatar
Ruddigger
Okay I tried 5 things now, I tightened the pins on the the harness plugs but still nothing happened, i did not have any spray but would it make any difference? any other suggestions, I heard that there is a wire that runs under the carpet that splits threeways to the other windows that sometimes gets corroded, anyone else hear this??
Old Nov 25, 2012 | 01:46 AM
Ruddigger's Avatar
Ruddigger
Bump someone has to know the answer
Old Nov 25, 2012 | 01:56 PM
radicaltimes's Avatar
radicaltimes
I am tagging along, My right front window only works from the drivers side most of the time.
Old Nov 25, 2012 | 08:01 PM
scwpd's Avatar
scwpd
Try pulling the boot between the door and check the wires that's where most people have problems
Old Nov 29, 2012 | 01:16 PM
kx250frider617's Avatar
kx250frider617
It's Wouk window lock button. Either replace the whole window switch on the driver door. Or you can by pass the window lock switch by cutting a certain wire and soldering it to another wire. My truck had this problem. Along with 4 others I know personally.
Old Nov 29, 2012 | 02:49 PM
Izero's Avatar
Izero
might be a short on the window lock circuit.... do a voltage test on that line...
Old Dec 7, 2012 | 12:03 PM
sl65black's Avatar
sl65black
I got the exact same issue with my 04 Ram 1500. I have tried 2 other switches and dident fix my problem. Is there anybody out there with some helpfull info PLEASE.
I have tried everything all the other guys have talked about,but no result
