front drive axles
Old Nov 20, 2012 | 05:56 PM
Jeffish's Avatar
Jeffish
Default front drive axles
06 Ram 1500 4x4 Quad Cab, Anyone know how much up and down play is acceptable on the front drive axle inboard CV joints? I assume none but both my shafts have almost 1 inch of play. No clunking noises but there is a low howling noise when driving.
Old Nov 20, 2012 | 07:57 PM
p38251's Avatar
p38251
Sounds like the hub bearing is going bad. The howl will get louder, may even start making a grinding noise as it gets worse. You should replace them both as soon as you can.
Old Nov 20, 2012 | 08:19 PM
Jeffish's Avatar
Jeffish
The play is at the inboard cv joint. There is no movement at the outboard hub cv joint so I'm not sure why it might be the hub bearings.
Old Nov 21, 2012 | 08:42 AM
p38251's Avatar
p38251
Sorry missed the inboard part. possiable bearing in the front diff. how many miles? how did the fluid look on the last fluid change?
Old Nov 21, 2012 | 06:32 PM
Jeffish's Avatar
Jeffish
just did the diff oil and it was fine. The shaft going into the diff is secure, the cv has all the play in it. Both shafts have almost the same amount of play in the inboard cv joints which I thought was a bit strange so thats why I wondered how much play is acceptable. Again I assume no play should be in the cv joints but I've been wrong before. lol
