Excited new member
Old Nov 20, 2012 | 07:38 PM
Nellim's Avatar
Nellim
Talking Excited new member
Hello I'm new to dodge form and I'm very excited to join. I have a 2007 ram 1500 4x4.i have no aftermarket parts or upgrades, yet. I take pride in having a well running vehicle, but as of late it's been real frustrating. I hope by joining DF
I could get input and advice. My current problem is a knocking in the front end at slower speeds joined with a small shudder in the steering wheel. I have takin my truck to mechanic numerous times and he can't find anything wrong with it. I have had stabilizer links replaced,and everything checked and greased but no luck, can anyone help.
Thanks for your time,
Cam.
Old Nov 22, 2012 | 10:03 AM
hibyte's Avatar
hibyte
Cam.
I'd be interested to find out the cause of this as I get the same on my '00 Dak QC 4x4 but its not constant.
Thanks
Old Nov 24, 2012 | 06:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Some of the problems i have seen is loose shocks, lower ball joints and loose bolts on the crossover bar ( just under the oil pan). I will move your post to the 4th Ram section.
Old Nov 24, 2012 | 07:54 PM
plumcrazy73's Avatar
plumcrazy73
An 07 is 3rd Gen
Old Nov 25, 2012 | 10:57 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^ Thats true.
Moved back to the 3rd Gen and welcome to the site
Instead of taking it to a general mechanic, take it to a front end shop that specializes in front end work
Old Nov 26, 2012 | 09:51 PM
PostalTwo's Avatar
PostalTwo
look close at the lower ball joints maby there dry sometimes when they get like that they will make a "pop" "crack" sound
Old Dec 30, 2012 | 09:09 PM
Nellim's Avatar
Nellim
Default Found the problem.
It turns out that the control arm bushing bolts were ceased to bushings. After removed I cleaned the bolt and found that it had corroded at least half it's diameter. Because bushing was ceased the strut had to be cut this added a lot to final cost but really worth it. Truck rides like new
Thanks to everybody for input and suggestions.
