rusted exaust manifolds
Old Nov 20, 2012 | 08:51 PM
dougiedododge's Avatar
dougiedododge
Default rusted exaust manifolds
I was recently checking out everything underneath my truck (07 ram 1500 4.7 flex)133,000 miles.I noticed that my exaust manifolds were rusty looking.Is this normal?
Old Nov 21, 2012 | 08:49 AM
p38251's Avatar
p38251
Yes. its surface rust from them being in the elements all the time. And the hot to cold heat cycles. If you live where they use salt on the roads it will happen faster.
Old Nov 22, 2012 | 12:24 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, anything that gets that hot is sure to rust
Old Nov 22, 2012 | 06:21 AM
ewing111's Avatar
ewing111
yep, definitely normal. Did you check for any broken manifold bolts? If you haven't had to change any it's likely you might with that many miles and some good rust going on. It's a common problem for some of them to break off.
Old Nov 22, 2012 | 11:29 AM
dougiedododge
Thanks guys,Ill definitely get under truck this weekend and check the manifold bolts.
