help reading gear pattern 9.25
Old Dec 1, 2012 | 04:56 AM
vietti's Avatar
vietti
Default help reading gear pattern 9.25
This is my pattern… I can’t determine if I need to add shims or reduce shims..
Any input would be very helpful.. thanks
[img=http://imageshack.us/thumbnmail.png]
Old Dec 1, 2012 | 08:07 AM
dirtydog's Avatar
dirtydog
Moderate User
Shims for Pinion gears: Thinner if the pattern is riding the outer edge, thicker if it's riding the inner edge.
But I think you actually may need to move your ring gear closer to your Pinion gear(which is much easier to do) and I think your not very far off at all.
References:
http://www.precisiongear.com/pgtechpatterns.htm
http://images.search.yahoo.com/searc...+pattern+chart
Old Dec 1, 2012 | 09:10 AM
Gone Fishin's Avatar
Gone Fishin
SPECIFICATIONS
AXLE SPECIFICATIONS
DESCRIPTION SPECIFICATION
Axle Ratio 3.21, 3.55, 3.92
Differential Case Flange Runout 0.076 mm (0.003 in.)
Differential Case Clearance 0.12 mm (0.005 in.)
Ring Gear Diameter 235 mm (9.25 in.)
Ring Gear Backlash 0.12-0.20 mm (0.005-0.008 in.)
Ring Gear Runout 0.12 mm (0.005 in.)
Pinion Bearing Preload - New Bearings 1.7-4 N·m (15-35 in. lbs.)
Pinion Bearing Preload - Original Bearings 1-2 N·m (10-20 in. lbs.)
TORQUE SPECIFICATIONS
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Differential Cover Bolts 41 30 -
Bearing Cap Bolts 136 100 -
Ring Gear Bolts 157 115 -
Pinion Nut Minimum 285 210 -
Adjuster Lock Screw 10 7.5 90
Backing Plate Bolts 65 48 -
Pinion Mate Shaft Lock
Screw
11 8 -
Axle U-Bolt Nuts 149 110 -
Old Dec 1, 2012 | 11:39 AM
vietti's Avatar
vietti
Thanks for the replay. I am doing this for the second time because the rear end is terribly noisy.
So you think I need to be closer to the ring ? meaning (thicker shim) I was thinking smaller shims?
