Do the passenger vents come off
Old Dec 1, 2012 | 03:29 PM
GRNDPNDR's Avatar
GRNDPNDR
Default Do the passenger vents come off
without removing the airbag?? or is the airbag entirely attached to the vent housings?
I need to get to the vents from behind but I really don't want to mess with removing the airbag..... I hate those things.
Old Dec 1, 2012 | 05:47 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can gently pry them up from the bottom and then pull them out
Old Dec 1, 2012 | 07:13 PM
GRNDPNDR's Avatar
GRNDPNDR
just the vent housings on the back? aren't they screwed in from behind?
Those are what I need, I'm putting some "Little Dot" LED's in my vents.
Old Dec 1, 2012 | 08:02 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The vent housing is usually plastic welded to the dash. The vent itself can be removed from the housing. The housing can be removed also if you decide to drill the plastic welds out or melt them
Old Dec 1, 2012 | 09:17 PM
GRNDPNDR's Avatar
GRNDPNDR
so in other words, I'm going to have to pull the airbag out to stick lights in there.
Old Dec 1, 2012 | 09:38 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You could use some sticky back 3528 or 5050 LEDs. I've got a ton of RGB strip left over
Old Dec 2, 2012 | 07:57 AM
GRNDPNDR's Avatar
GRNDPNDR
The Little Dot's are sticky back. they're a 5050 SMD with a sticky pad on the back, but I need to be able to get into the vent to stick it to the top, and run the wire.
Old Dec 2, 2012 | 07:52 PM
GRNDPNDR's Avatar
GRNDPNDR
As it turns out you do need to pull out the airbag, but only a bit, it doesn't even need to be unplugged.
Once you pull the airbag out the vent housings are just held in with clips, you can easily bend the rubber trim and they come right out. In my case they fell right out in my hand probably from loosening the trim previously.
Old Dec 2, 2012 | 08:07 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You should make a good How To with pics to help others out
Old Dec 2, 2012 | 08:16 PM
metaldad's Avatar
metaldad
airbag is not a big deal to remove.
4 10mm bolts, a dozen or so 7mm screws.
just be sure to pull the neg. batt. terminal.
you should disconnect the electric connector because it's just long enough to get your mitts in there
