4.56 gears price. I got a quote. have a few question.
Old Dec 7, 2012 | 09:20 AM
  #31
Izero's Avatar
Izero
I edited my post when the forum updated to show me your post.. :-P
Old Dec 7, 2012 | 06:25 PM
  #32
jj141979's Avatar
jj141979
Originally Posted by abarmby
Will do
But either way....I think I'll be happy when they're installed next week (fingers crossed the noise isn't too bad)
Al.
Make sure you check back Al! I wanna hear what its like to have 4.56 in our trucks!!!!
Old Dec 7, 2012 | 08:17 PM
  #33
abarmby's Avatar
abarmby
Will do bud. :-))
Old Dec 8, 2012 | 09:02 AM
  #34
p38251's Avatar
p38251
Some people run tuners to change the shift points. Gear changes will not effect the speedo. Tire size change will. I have found that a tuner for me is not necessary.
Old Dec 8, 2012 | 03:22 PM
  #35
HammerZ71's Avatar
HammerZ71
Been running 4.56s since spring of '05 and have never heard a hint of a whine. Although some report a slight whine with certain brands of after-market gears that have not effected performance.
Speedo reads off the ring, so gearing does not effect reading. Only tire diameter directly effects the speedo.
Drastic gear change (as well as just a drastic tire size change) will effect transmission shift points to a small degree. I have my shift points (and speedo) changed with my tuner - with the aggressiveness of the shifts being in direct proportion to how hard I'm on the throttle.
ALL ring & pinion sets ship with a protective phosphorous coating which wears off the surface during break-in. Heat causes a chemical reaction with this material which acts to reduce the effectiveness (lubrication properties) of the gear lube. Hence, YOU NEED TO CHANGE THE FLUID AFTER BREAK-IN. Plus, you really need to inspect the gears for proper wear pattern after break-in. So what better time to do both than when changing the fluid at or around 500 miles???
Personally, I'd hesitate to use a shop who does NOT recommend a post break-in fluid change AND a visual inspection of their work...
Old Dec 10, 2012 | 10:18 AM
  #36
Izero's Avatar
Izero
+1 on the bold & underlined above...
Welcome back Hammer!
Old Dec 10, 2012 | 01:36 PM
  #37
Ryan Dunbar's Avatar
Ryan Dunbar
The break in gear oil debate rages on. It's on Pirate too. from the factory they don't change the gear oil, but supposedly they lap the gears on a bench at the factory :shrug:
Question for those with 4.56's. are any of you running factory wheels/tires. I have the factory 20's (so about a 33" tall tire) and am thinking 4.56's.
What RPM do you guys run at 70? i'd like to be 2500-2700ish for towing.
Thanks!
Old Dec 10, 2012 | 02:16 PM
  #38
Izero's Avatar
Izero
There are calculators on-line that will do the math for you on that. Do a google search for them.
Old Dec 10, 2012 | 02:52 PM
  #39
Ryan Dunbar
i did. but most of them just give you 1:1 ratio. I'm getting 3200 rpm at 70... but then i should multiply that my .67 right? which gives me 2144... which seems way too low...
Old Dec 10, 2012 | 02:57 PM
  #40
Ryan Dunbar
ok, i found one that lets me enter final drive... i thought the 03 had a .67 OD but i'm finding .75 online...
anyone know
with a .75 i'd be in the neighborhood of 2250 with 32.5" tall tires and 4.56's.... does that sound right?
